Stereo problem .. ..>>rev whining???
DRIFTKNIGHT_240
Car: 240sx Zenki s14 [going sideways]
i rewire the speakers and am using an amplifier only front and back, no sub///
When my stereo is on, at low volume and am driving, as the rpm' s go higher you can hear a whinig in the speakers .wtf //////.the higher the rpm the loud the whining//? ..Has anybody had this problem before?Any way i can fix it ? i need help this is annoying me
zerepdivad
Car: '90 240sx . '02 Lexus IS300
WHY DID YOU POST THIS 3 TIMES???
roadboy240sx
Car: I like Nissans
you have a bad ground some where. it happend to me, i just ran a ( - wire ) from the headunit to the battery and problem solved.
DRIFTKNIGHT_240
cuz i havent fix it yet!!!!!!
moulton712
Car: coupe, hatch, both s13s
also keep your rca's away from power.
maybe you installed your main cable for you amp on the same side of the rca's?
DRIFTKNIGHT_240
roadboy240sx wrote:you have a bad ground some where. it happend to me, i just ran a ( - wire ) from the headunit to the battery and problem solved.
You re right about the bad grond so i wire directly to the negative battery pole and the whining stop Thanks bro!!!!
