Stereo problem .. ..>>rev whining???
DRIFTKNIGHT_240
Car: 240sx Zenki s14 [going sideways]
i rewire the speakers and am using an amplifier only front and back, no sub///
When my stereo is on, at low volume and am driving, as the rpm' s go higher you can hear a whinig in the speakers .wtf //////.the higher the rpm the loud the whining//? ..Has anybody had this problem before?Any way i can fix it ? i need help this is annoying me
zerepdivad
Car: '90 240sx . '02 Lexus IS300
pioneer head unit i assume?
Bad ground.
Check that your ground wire is direct to metal, preferably someplace on the chassis, scrape away some paint for better contact.
zerepdivad
AZhitman wrote:Bad ground.
unlikely. Generally most time's i've seen this issue is A) the most common is a blown pico fuse internally on a pioneer head unit usually caused by diyers who think it's a good idea to pull rcas out of their amps while the radio is on. And when the rcas touch ground it blows this pico fuse internally.B) Don't see it that often but low quality signal cables ran near power sources can also cause this issue..
Modified by zerepdivad at 12:20 AM 7/3/2009
Unlikely?
I know you're a pro, Dave, but it's very likely, especially in a DIY install. I think "B" is the second-most likely cause in a DIY system.
At least start him off with the basics. My money is on a crappy ground.
DMan II-40
Car: 1995 240SX SE
i don't think he is reposting on purpose. It happened to me the other week when I had a for-sale thread open, and when i refreshed it reposted the topic. I didn't notice until I had 3 of them lol.
Nesquick
Car: Rb26 Kouki Silvia
its definitely grounds.
i had the same thing with my alpine system, so i threw a bunch (3-4) more grounds in the system. took the whine away.
