AppleBonker »
https://forums.nicoclub.com/applebonker-u101518.html
Wed Mar 10, 2010 2:24 pm
Yup, the alpine amp you posted previously mated with a dual 4-ohm 10" sub would work nicely (I think the sub is model 1042D - there is probably a 1022D as well, but you don't want this one). That would push 500 watts to a sub that can handle 500 watts and would certainly be a nice addition to give you some thump.
A ported box will be a bit sloppier. The Type-R isn't well known as a sound quality sub, but it can hit hard. It will work quite well in a ported box, and would give you more volume. I don't use the word sloppy as a huge negative, so don't take it that way. A sound quality sub in a sealed box hits much more crisply. However, it takes a lot more power and a decent priced sub to get the same volume (this adds to the price quite a bit). As long as you're not planning on winning any sound quality competitions, those items on the budget you are working with will give you a stereo 100x better than stock.
For what it's worth, Doc is still running a ported enclosure I believe. Ported doesn't sound bad, just not as clean as sealed. Most people can't tell the difference (and they are lucky - trying to obtain the highest quality sound becomes a VERY expensive addiction).
And, as far as the 10 vs 12 goes, a 10 will hit cleaner than the 12, but it wont reach as deep. It also takes less space in the trunk, so a lot of people go that route. The sedan is significantly deeper in the trunk, so you would be able to fit a 12 far more easily than a coupe. But, I think you are probably making the right decision by looking at the 10.
