When you guys pull out your cluster I would recommend that you swap out your dash bulbs with some Polargs. Much brighter than the stock 12 yr. old dash bulbs. When I put my guages in I swapped out my dash bulbs. Makes a big difference.Kittychubbs wrote:I have a Digital cluster it has a lil dash projector too.i have a question steps on installing the cluster on my 240sx its a 91
its the wireing the same ectect .and the projector do i make the hole on the top of dash< where do u recomend me to do thanx alot
You can check out the write-up on cluster bulbs on ImportIntelligience but as far as buying them...I found them cheaper on ebay. Polarg 194 I think you need 3 sets for Nissan clusters.Kittychubbs wrote:polargs ohhh i see, do they have a website?i will check thank you thats a really good idea!
Mine came in the car. But you can pick one up on ebay most of the time.Nissan240Sound wrote:Where did you get your digital cluster from. Im in need of one since my speedometer and odometer stopped working on my '90 240.
