180fan »
https://forums.nicoclub.com/180fan-u3602.html
Thu Aug 02, 2007 7:21 am
yep, you'll need to lift and suspend the motor a bit.
you can also go about it a semi-similar way, a bit more ghetto/dangerous though. unbolt the motor mounts and the transmission mount. lift the setup at the oil pan with a good sized wood block where the jack is going to meet the oil pan. setup jack stands along the transmission and leave the jack at the oil pan till you're ready to drop the pan.
