S13240 wrote:What they mean as a stepped flywheel is a flywheel that has two different height levels on the flywheel itself. The other kind of flywheel is a flat surfaced levelled flywheel.
This didn't answer what he needs to actually do.
Using the Sentra SE-R as reference in this case would be wrong. The Sentra is a FWD and the SR20 is RWD, causing them to have completely different drivetrain layouts. When I went to have my flywheel resurfaced, the last owner had worn the clutch disk down so it was metal to metal and it stepped the flywheel itself (in a way)
Anyways, the mechanic measured the thickness of the flywheel in certain areas and determined the face itself is flat, not stepped. The only part of the flywheel that has an offset surface, is the middle where the flywheel bolts go through.
I'm pretty sure that's right, someone correct me otherwise.
