Nismo_Freak wrote:The next time you are autocrossing, take your left foot and apply light braking. The front end of the car will turn in allowing you to reduce your steering angle.
This is of course assuming that you don't have really stiff springs. If you do, then doing this is pointless as your car will not dive.
"Throttle steer" is a fairly general term for it. In most cases where it's a good thing, it's power oversteering. However, power oversteering doesn't mean you need to lose traction. Basically, as you turn in a corner, various shearing forces act on your tire due to the centripetal force being applied to your vehicle, and then when torque is applied linearly to the tire it begins to follow a non-straight path. As centripetal force is pulling inwards, your tires will mostly be sheared so that they will bias outwards. If you're driving a RWD car, it will move the back of the car towards the outside of the turn. FWD will move the front of the car towards the outside of the turn (understeer... bad).
In reality, you don't even need that much torque from your engine to do it, but your alignment settings in the rear make a fair amount of difference as to how your car will power over. Most notably your rear toe setting.
If you're asking HOW to do it... just go into a turn and increase throttle input.
