Steering wheels not straight after rotor changed
Shiryuu
I had my front rotors replaced with some power slot ones and now the steering wheel does not point straight anymore. so in order for me to go straight, i have to turn the steering wheel about 15 degrees to the right? Any ideas how to fix that?
94_240sx
Car: 94_240SX
Alignment should fix all that, but simple rotor replacement shouldn't cause something like that. Weird.
Hmmm.
There's no reason replacing the rotors would affect that.
Find out who did what. We need more info.
placham
Car: 1992 Geo Prizm (4AFE)---Gone
1990 Nissan 240sx Coupe (RB20DET powered),
1994 Toyota Celica GT (3SGTE swapped), 1995 Nissan 240sx KA24DE,
2011 Nissan Sentra SER Spec-V
Shiryuu wrote:I had my front rotors replaced with some power slot ones and now the steering wheel does not point straight anymore. so in order for me to go straight, i have to turn the steering wheel about 15 degrees to the right? Any ideas how to fix that?
If your car is going straight and not pulling to ether side. Than screw it, remove your steering wheel and reposition it so it's straight again.
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Were the old rotors making contact? But are the tie rods loose at all. Did someone unbolt the strut at all?
94_240sx
Car: 94_240SX
I have another idea. Maybe pads are touching a rotor one side, so one side is not rotating freely?
Shiryuu
yea i am a bit confused as well. i brought the car back and left it with the mechanic and he said he'll check it out.
but i had the RUCA, Rear Toe Arms installed, and replaced all 16 wheels studs while doing the front rotors as well, you guys think that would have caused the alignment go out?
iitywygms
Car: 1993 sx se
Shiryuu wrote:yea i am a bit confused as well. i brought the car back and left it with the mechanic and he said he'll check it out.
Um, yeah. Changing all that is a lot different than changing just your rotors. You changed the suspension Get an alignment. end thread.
nissanman04
Car: '90 240SX, '95 Subaru Legacy
So why are you buying these adjustable parts if you don't even know what they do?
Shiryuu
ah ok. thank you.
