Steering Wheel wont center after turn
Summary:
-Steering wheel on 05 Altima 2.5S needs to be forced back to center after performing a right or left hand turn, or lane change.
Possible issue:
-Control Arm bent due to going over small curb, daily (for about a week).
-going over small curb while making a SHARP right turn, at extremely slow snail speed.
-Alignment issue? even though car seems to drive straight.
-Sway bar links need to be changed anyway, but could this be the issue?
Additional info:
-Car seems to be well aligned, doesn't drift in either direction during high and low speeds.
-Car doesn't shake much in high speeds
-Control Arms replaced 3 years ago
-Inner and Outer Tie rods replaced 3 years ago
-Sway bar link replaced 2 years ago
-Struts replaced 1 year ago
-Steering Fluid is topped up at Min (for cold weather)
FULL STORY:
Hi, my steering wheel on my 2005 Nissan Altima 2.5S is sticking and not returning to center after turns.
I started a new job 2 weeks ago, the entrance to the parking lot is a very sharp right hand turn and i usually have to go over the curb slightly in order to make it. My steering was fine on the way to work but while leaving i noticed that the steering was very stiff. While driving I noticed that after i make a turn in either direction, the steering wheel seems to lock in that direction (Left or right) and i have to FORCE it back in the middle (very dangerous).
I just got home and dont plan to drive it again until i figure out the issue. I remember having either the same issue or similar 5 years ago, I think I just had it aligned and it resolved the issue, does this sound right?
Thanks in advance,
Salah
