IvoryJ30t »
https://forums.nicoclub.com/ivoryj30t-u9485.html
Fri Jul 23, 2004 9:07 am
tension rods are also called radius rods. the lower control arms are different.
when you take one of the front wheels off, the hub [what the wheels bolt to, with the brake rotor and whatnot] is connected to the lower control arm via the ball joint. the lower control arm connects the bottom of the hub to the chassis.
the vibration could be related to an imbalanced wheel or worn tie rod ends, worn suspension bushings, ect...
you have to check for excessive play in components and bushings, tie rods, ball joints, ect...
