apzak »
https://forums.nicoclub.com/apzak-u2735.html
Sun Oct 19, 2003 4:39 pm
I'll look into everything else. I don't think its my tires because I had this before I replaced the tires and when new tires were put on they were balanced. Suspension is the next thing i'm modifying so i'll probably end up finding out whats up.
Quote »One of the most troublesome bushings on the 240SX and 300ZX, this silicone filled "donut-shaped" bushing which is pressed into the Tension Control rod, is one of the first bushings that wears out. When it fails, the viscous filling will leak out, and corrode your front suspension's paint finish, and will cause erratic steering (especially at highway speeds). [/quote]hmm.. I noticed on the highway if I let go of the wheel the car will sometimes drift to the right, or sometimes drift to the left. It's either the brushings, or there is a slight slant for water run-off but I don't know if thats (the slant for water to run off) enought to make my car drift to a side.
