Steering Wheel???
Nissan dominates the drift scene - Always has, always will.
IlIkEmYz
Car: 06 Z
i want to get an after market steering wheel/ hub (Detachable), cause i heardit increases steering responses.
What steering wheel/ removable hub do you have/ recommend???
BuudWeizErr
Get the L2 quick release. It's what everyone has because it's cheap and solid. Check out phase2's site to look at it.
Personally, I have a Momo Hub, L2 quick release and a 350mm Momo Race wheel. I like the smaller wheel, but anywhere between 340 and 370 or 380 is pretty good.
sixxdeuce
Car: 93 rx7, G35coupe 6mt
is the l2 a ball bearing type? I need one of those.
BuudWeizErr
sixxdeuce wrote:is the l2 a ball bearing type? I need one of those.
yessir.
chmercer
i cant think of a reason an aftermarket wheel would increase steering response. i guess you mean a smaller steering wheel? l2 hub is good, i use one myself. got it from http://www.splparts.com. if you can, try to get a suede wheel and some driving gloves. makes it much harder to loose your grip on the wheel.
skillzilla
Im looking at the detachable hub, mainly to get the wheel closer to me because I have long legs, which makes heel/toe a biatch with the steering wheel at stock placement.
L2 huh? Ill check it out.
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
I'm with skillzilla on that one. I'm only 6'2", but can't get seated in the correct driving position without bumping my head against the ceiling. I think I could lean back a little better and get headroom if I added a couple of extra inches onto the steering hub. A smaller diameter steering wheel would also give me some knee room. It's a pretty good anti-theft device as well.
How difficult is this install?
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
not hard to install, i have the L2 and used a hub and steering wheel (we think its Nardi personal) off a buddys RHD clip, its tooo tall for me so im looking for a shorter hub. on s14s u have to remove the airbag but thats not hard, T50 tamper-resistant torx bit after waiting for the airbags to lose their reserve charge and your good to go.
-Dan
Return to “Nissan Drift Forum”
