kane2g wrote:importnut has a writeup on this.you'll need a safety T50 torx and 19mm socket, probably philips and a beer.
Where does the T50 Torx come into play? I ditched my stocker for an after market and all i did was remove the 19mm nut and pull like a mofo. This was for an '89 S13 (no cruise either). HeHe...maybe i wouldn't have had to pull so hard if i knew there was another bolt in there somewhere....
If your going to put your stocker back on, i'd mark the position on the spline with a Sharpie or something. Otherwise you might have to pull it off and on a few times to get it lined back up correctly. I had to do it about five times, very annoying.
K
