steering wheel still shaking
toledo240
i got a 92 240. new shocks/springs, new tc rods, new outer tie rod ends, inner tie rod ends look fine. and tires and balanced even though front tire thread is not even. sterring wheel shakes after 60 mph and gets more violent. what could it be?
Zion8561
Car: 92 Nissan S13 Fastback
I had shake at 65mph. Changed the balljoints and tie rod ends and it went away.
Actually I changed both front lower control arms since PDM had a deal on them. Now I got spares
dousan_pg
Car: 1995 240sx 1991 infiniti q45 1993 nissan 240sx
even if your tires are balanced, if the tires are uneven/flat spotted it will still shake.
might look into a new pair of tires.
toledo240
forgot to mention this also does this on my track tires too
McRussellPants
Car: 92 240SX
my tire has a small flat spot from when I was learning Z brakes and I did some weird plow brake lock thing.
my wheel kind of shimmys at 60....
A shake is something loose if its not the tire.
Eddie
Car: 1995 240sx se
Are your wheels hub centric? If not hub centric rings may be a cheap remedy to your problem.
My car used to shake between 65 and 75 because my wheel was not centered on the hub. Hub centric rings tamed the shake down to a shimmy. The shimmy is do to a "z brake" flat spot.
