^xero^ wrote:I had the exact same problem on my mitsubishi and it turned out to be the rack and pinion.
ok so your rack n pinion was screws on the mitsu, graphicxz i wouldnt consider a problem with your rack and pinion a popular item to cause your condition, from the imput of this thread, i would trouble shoot the possibly warped rotors and pads first, tc rods/bushings, then last but not least if that hasnt fixed the problem you could entertain the idea of inspecting/rebuilding/replacing the rack and pinion.
xero- did you rack and pinion leak powersteering fluid at all when you were getting these pulses in teh steering wheel? or what exactly was causeing the shaking, somthing loose?
