Steering Wheel Shakes
SilverI30
Car: infiniti 1997 I30
wassup guys?( Seems whenever i acclerate the steering wheel shakes like crazy! But once the car is rolling its back to normal. Any ideas on what the problem could be?
audtatious
Could be alignment or the rims really need to be balanced.
SilverI30
really???? ok ill check those two out. i was thinking perhaps the calipers?
audtatious
If it happens when you hit the brakes, it could be caliper/rotor related. If you hear the pads rubbing, it could also be brake related. If you have a shimmy while accelerating, it is probably alignment/balance/wheel/suspension related.
SilverI30
audtatious wrote:If it happens when you hit the brakes, it could be caliper/rotor related. If you hear the pads rubbing, it could also be brake related. If you have a shimmy while accelerating, it is probably alignment/balance/wheel/suspension related.
yeah it was shaken when i hit the brakes, so i had the rotors and brake pads repalced. front and back....but now when i acclerate the steering wheels shakes like crazy...why is that? the alignment i don think so, cause the car would put to the left or right, right?
audtatious
Could be an issue with toe which would be an alignment issue. Most of the time, when I have "the shakes", it is an issue with the tires or balance. I would have that checked first.
SilverI30
also i noticed, when i hit the gas hard, thats when it REALLY shakes, but ill check out the alignment and tire pressure....and get back to you guys
BOBCAT
Car: 2000 Maxima, 94 SER
Mine shakes at real low speed of like 30-35 mph. It happens when i turn and driving strait. Feels very weird. Usualy happens when my car is just warming up. Also, If i air up the front tires to about 33 psi it will drive like a dream but not turn as well as it should.
