steering wheel shakes at 45mph any faster it stops
LeroyBrown
Car: 1995 nissan 240sx s14 blacktop
its a 95 240 not sure what it is maby one of the bushings. im sure this has happend to alot of you.
danielsan
Car: 1991 240sx coupe SE
my tension rod bushings are worn out, more so on the passenger side. i get a shake between 45-60 mph and then smooths out. im blaming the tension rod bushings.
LeroyBrown
thanks bro i believe thats what it is. sounds like the same symptoms as yours.
danielsan
tie rods and out of balance wheels will add to it.
2fourOh
Car: 93' nissan 240sx
Normally when your tie rods go out you'll hear a clicking not just a vibrate. Tension rod bushings(or lack ther of) will only have an effect on your bump steer on rougher driving surfaces. Just rolling down the road the Tension rod's have very little effect on the smoothness of your ride they're ther to control the forward and backwards movment of your lower control arms. So unless the bushings are virtually non existent they arnt the source of your vibrating problems. bring it to a tire shop have them do a high frequency balance on all four tires shud solve your delima and shudnt cost you much either. Let us know if that fixes your problem
danielsan
worn tie rod ball joints will cause the wheel to shake. i know this i have had 3 cars that did this. a 93 taurus wagon, 90 integra, 94 ford probe. new tie rods cleared it up.
