steering wheel shake
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
Jediknight77
Car: 2008 Infiniti G37 Coupe Journey
Hello All,
I’m new to the site but not new to Nissan/ Infiniti. I currently own a 2008 G37 Coupe Journey model. I recently had to change my tires be the ones I had were worn out. My problem is I’m running 245/40R19 all around because I wanted to have the opportunity to rotate my tires when needed. This is where the problem has started I got all 4 brand new tires along with a 4 wheel alignment. The problems I’m having are at high speed between 60-80mph my steering wheel starts to shake not a lot but noticeable it wasn’t doing that before. I’m just wondering if it’s because I went with the same size tire all around and in the front I didn’t put the recommended 225/45r19. Any advise would be helpful. Or if anyone had this problem and what did they do to correct it. Thanks guys!
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
The issue is related to tires or balancing. Have them road force balanced.
carldu
Car: 08 Titan
If you got them balanced before, the shop didn't do it correctly.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
