steering wheel shake at 60+ MPH
91nissantwo40sx
here are the things i know:-my alignment is a bit off
-2 front tires have like 10% tread left in them (dont know if i should buy new tires because ive been thinking of getting some new wheels soon)
-2 rear wheels have new tires in them with about 99% left and also both balanced (only had them for about 4 days)
-Tokico blues with megan lowering springs
efrain240sx
Car: 1992 nissan 240sx HB
its ur front tires they are un-balanced thats what makes ur steering wheel shake
sormeroid
Car: '89 nissan 240sx hatchback (2 of them)
im having the same problem but i have newer tires like 6 months old. i hit a pothole now it has the same problem but at 55mph.
91nissantwo40sx
efrain240sx wrote:its ur front tires they are un-balanced thats what makes ur steering wheel shake
yea i thought so
i will pick up some used tires for now until i decide with the new wheels
efrain240sx
sormeroid wrote:im having the same problem but i have newer tires like 6 months old. i hit a pothole now it has the same problem but at 55mph.
You must have bent the rim a bit, if so take it to a tire place to get it balance, it will stop the steering wheel shake but it might make a wired noise because of the bent part
S14toRPS13
I had the same problem a while back. After I got new tires and an alignment, the shaking went away.
adrianfromthecastle
Car: 1992 Nissan 240sx
you might have arthritis
EvillE423
I would say get an alignment and balance those wheels. The roads around here are ****ty and as soon as I leave the alignment shop I'm constantly swerving to dodge one pot hole and hit another. I refuse to pay for alignment until they fix the roads.
S13xCrazy
Car: 1993 240sx Vert, 1993 BMW 325i, 1993 Honda CBR F2, 1998 Infiniti Q45,
91nissantwo40sx wrote:
yea i thought so
meh just go ahead and take it to a shop and have them balance them if you don't want to get new ones.
ca18tt1978
Car: 1991 240sx/180sx ca18det swap
(1) Alignment does not cause shaking unless you have a bad bushing or balljoint .This would cause shaking and alignment problems .(2) Bald tires will cause slight shaking .If you car is lowered the camber wear will throw the ballance of the tire off .(3) Bent wheel will diffently cause the shaking .No balancer made will remove the shaking if you have a bent wheel .
Now if you feel the shaking in the steering wheel then its usualy in the front of the car (wheels mostly) if you feel it in the seat then you might have muitiple problems the least of your worries would be a bent wheel .I know many of you are gonna ask "How do you know this" I know cause i work for a tire shop and have worked for 2 car dealers in the past 6 years working with the best equipment money can buy .Hope this helps .
Soravia
Car: 2003 Audi A4 1.8T
Have you tried replacing your steering chassis parts like tie-rod ends and stuff? There's no point getting an alignment if your tie-rod is busted.
0wn3r
Car: 1997 Nissan 240sx SE track car (SR20DET, caged)
i would think a bent rim would cause vibrations before 60mph as well...then again, I've never bent one of my rims so I wouldn't know.
But I just had the same problem... usually between 60-65 you'll notice it and around 70+ it will mostly go away. One of the weights probably fell of so I just had them rebalanced and it went away.
21nemesis
Car: 1993 240SX SE
I had pretty much the same problem when I hit 50 and when I'd hit the brakes. Changed the shocks, got a little better. Today I changed the tension rods(Megan Racing tension rods), since the busings were blown from the OEM ones (that's what 200K miles). Took it for a test drive and the car runs smoothly! Check your tension rods and bushings.
turboabuser18
Car: saab ng900 2.0 turbo
yeah it's def one of two things. your tires and i've had a similar problem with my moms brakes. her rotors got warped and it shook pretty bad.
S14-KOUKI-MONSTER
Car: '97.5 Kouki s14 le w/Kouki s14 sr & '03 Xterra w/6" lift on 33s
To confirm/rule out the front tires being the problem, just rotate the fronts to the back, backs to front and take it for a drive. If the steering wheel doesn't shake, then it's the tires for sure.If the steering wheel still shakes, could be a ball joint, tie-rod, or badly worn rack bushings.
