steering wheel removal
Mike09
how da ya pull the steering wheel off do you need something or what. Is it locked in?
JNM240
Car: 90 Coupe, 90 Hatch (CA18DET)
No, you just remove the horn pad, remove the bolt, then yank it off. You might want to bang it off with your hands, its usually on pretty tight.
drjohn
You might want to drive the car straight into the drive to center the steering wheel and than rermove the horn button and loosen the steering wheel nut but don't remove it. Then pull the steering wheel towards you and wiggle it at the same time and it should pop off. Leaving the nut on the shaft keeps you from busting your face with the steering wheel when it comes loose.
Mike09
appreciate the help especially cause i don't want to taste the steering wheel
w1ngzer0
Car: Pfft. i don't own a box
i got it off but my release hub doesn't work? I meen am i suppose to buy another thing or what?
Modified by w1ngzer0 at 8:45 PM 2/21/2005
s13sr20chris
release hub?
