Dano »
https://forums.nicoclub.com/dano-u2493.html
Mon Nov 14, 2005 8:30 am
ive done a number of em, if u have an s14, you'll need to get a T55 tamper resistant torx bit to remove the airbag (MAKE SURE you disconnect the battery for at least an hour to drain the capacitor charge for the airbags (it stores a charge for a while after the battery is disconnected) and once u get those out, carefully remove the airbag and remove the main nut, then pull from the top, pulll from the bottom, shake vigorously or watever u got to do, just dont turn it and strip the threads, lol. I've done a number of wheels and never required the use of a puller... just muscle it. S13 is just the nut, no airbag... Best of luck to u!
-Dan
