suby01 »
https://forums.nicoclub.com/suby01-u59378.html
Tue May 29, 2007 11:45 am
at every start, after the steering wheel/column has zipped into place, when I first lay my hands on the wheel and apply downward pressure, the steering wheel clicks down about five millimeters in my hands, to a lower position. Apparently, the column isn't properly "locking" into position in the vertical plane, until downward pressure is applied. After doing that, the column remains fixed and doesn't jiggle at all. However, this happens with EVERY start in the exact same way each time.
Anyone else have/had this problem? Thanks..
