Steering wheel off center since lift????
Finkle
Car: 2004 Pathfinder Platinum LE 4x4
I had an alignment done after my 2" lift was put on and now my steering wheel is off center. My local tire shop says everything is fine after 2 checks on their alignment machine. It's frustrating.
Does anyone else have this problem after a lift? :wtf2:
C-Kwik
If the steering wheel is off center, it means the shop did not set the wheel to center before performing the alignment. Take it back and have them redo the alignment at no cost to you. This is a trivial problem that should not have occurred and they should have been able to remedy it quite easily. Then, never go there again.
fueler
Car: 2 Nissan's
2 BMW's
^^ agreed , part of the alignment is making the steering wheel straight, if they don't make it center then i would ask for a refund
