Steering Wheel Noise
All things Altima Coupe.
dpn
I'm starting to hear a friction noise coming from the steering wheel whenever I turn the wheel, like a scraping noise between the steering wheel and the column.
Anybody else run across this, and if so, what did you do???
Thanks,
DPN
Scandinavian Flick
Car: 2008 Nissan Altima Coupe 3.5SE
there is a service bulletin out about this noise, do a search because there a write up about it somewhere on this forum
SniperJoe
Car: 2008 Nissan Altima Coupe 3.5 SE CVT, Premium, Tech, VDC.
The tech bulletin you are looking for is called "NTB08-015a 2007–2008 NISSAN ALTIMA; SCRAPING NOISE FROM STEERING WHEEL.pdf"
Chicago Coupe
Car: 2008 Altima Coupe 3.5 SE Dark Slate
I have this exact same problem!! I took my coupe to the dealer and told them about the bulletin, but the tech said the bulletin fix didn't work, so he replaced the spiral cable. The noise appeared to go away for a few days but came back. It's really frustrating because it just doesn't sound normal. I'm going back to the dealer next week. (Hopefully they'll figure it out!)
racingtiger03
Car: 2008 Altima Coupe Code Red 2.5S
how about that.. I always heard it and just though I was being too picky of the car. Definately getting this fixed next oil change!Thats why i love this place! lol
Sparktree
Car: Altima Coupe 2008 3.5 SE MT
I had the same problem, and the dealer actually fixed it on it's first try! Now if they could only fix my other 5 problems...
EJ_Red
Bringing back the old thread. The spiral cable was replaced, TSB was done, and the steering column was replaced. The noise is still there. Any suggestions?
lecros101
Car: 2010 A/C 2.5s CVT
I would complain my A$$ off to the dealer.
Mattv609
Car: 2009 Nissan Altima Coupe 3.5 SE V6 Azure Blue
does this noise occure when you turn the wheel pretty much almost all the way to either the left or right????
EJ_Red
When you rock it left and right. It only comes on after the car warms up or after 5 mins of driving.
