bigdog76 wrote:........So many features that I take for granted that brand new cars dont have unless your spending over $50,000
And to think that our Q's cost that much as long as 15 years ago. It's quite an automobile.
I've been having similar problem with my 90Q since I bought it 6 months ago. I'm starting to think it's key or ignition cylinder related and has nothing to do with any controllers. The reason I say this is a couple of weeks ago I picked up the wrong set of keys on the way out the door (Toyota truck), put it in the ignition, realized my mistake and pulled it out. Since then when using the correct key (not OEM) the tilt and retract works much more often but the key sometimes sticks when putting it in the keyhole and it may take 2 or 3 tries to get it to work properly.
But, if the steering wheel automatically fully retracted and fully tilted up after the last use the key slides right in an works great. This leads me to think that a worn out ignition cylinder is the culprit and possibly the non-OEM key. I haven't tried the OEM valet key but if all is well when using it then it points to the cylinder.
My Q spent most of it's life sludging in the red dirt of the Sierra Foothills and blowing out the key cylinder with compressed air did help. If you can afford it a visit to a locksmith to clean up the lock cylinder it might be money well spent. It is a nice feature to have working properly and I get the same comment from new passengers in my Q's. Good luck.
