Nicky Altima »
https://forums.nicoclub.com/nicky-altima-u107070.html
Wed Mar 31, 2010 4:04 pm
A couple things can cause vibration in the wheels:1) Did you get the right hub centric rings size for your rims/car?2) Check if you used the right lug nuts. Most aftermarket rims use tuner style.3) Most of the time, you need to have an alignment check whenever you make any changes to the suspension (wheels, springs, etc).
