Steering wheel hub problem-S13 Chuki
benz88
Car: 91 240sx
So I went to install install my hub and come to find this behind the wheel
how am i supposed to install the hub with this there. All the writeup's ive looked at havent had this piece or talked about this.
biggie
Looks like that should come off, not sure what it is, unless someone already had something aftermarket on there or the steering wheel came apart.
benz88
Car: 91 240sx
behind it is bare, i took it off and its just the white plastic that holds the wiper/signal switches. No horn.
This is for the cruise/horn i guess.
biggie
Should look like this somewhere behind it:
benz88
Car: 91 240sx
Thats the wiper/signal Assembly, Mines not like that. Mines white
biggie
Ok, never seen a 240 hub like that. Maybe someone else has.
benz88
Car: 91 240sx
i know. Its fustrating as i just got my new wheel and my stock ones all ripped and ghetto, now i have to keep it on.
EnjoiNismo
Car: 93 240sx
I believe that's for cruise control, I took it out when I put on my HUB
Syrus33
Car: 1993 Nissan 240sx Hatch
RB20DET
The plastic circle with the 2 tabs is the steering angle sensor for super hicas, you can either remove it if your hicas doesn't work or has been eliminated. Else you have to buy the proper hicas hub adapter.
benz88
Car: 91 240sx
Thanks guys, Ill remove it and make a custom horn contact.
