ARKQX33V6 »
https://forums.nicoclub.com/arkqx33v6-u165721.html
Thu Mar 31, 2011 12:12 pm
Check the tire tread carefully, look for wear signs on the edges, look for cupping on the tread, how much left to tread bars? Sounds like front shocks inside the tower struts are going or gone, see if they have been done in your records. Take a look at the front McPherson strut members are the springs rusted, the end of spring missing there plastic coating. Look at shocks, missing or broken rubber covers, oil mist around lower steel, if so, worn.
That car is hard to bounce by hand, but give it a try and see if any rebound takes place, it should stop bouncing when you stop jumping on the bumper, but as I said this test is hard to do.
Instead jack it up and remove a tower and try to extend and close the shock, it likely is worn, loose, no dampening. Test the top bearings by turning the wheel unladen lock to lock, engine off and feel for roughness, looseness and hear squeaks.
At 160,000 miles the shocks should have been replaced 2-3 times.
While under the front end take a pry bar and try to spread joints, links at connections, this will indicate wear and upcoming clicking noise.
A large pry bar 5' can be put under the raised front wheel and the rear of the bar raised and lowered to indicate bad ball joints and top strut tower wear.
Check your records for:transmission oil changes, transfer oil changes, coolant changes. The rear brake shoes will lat a long time, but the brakes need servicing: cleaning, greasing, de-glazing, the front brakes need an overhaul with caliper cleaning, lubing, and the brake fluid changes. All of which is normal routine maintenance.
Your records will indicate how and what was done.
