Postby
BlackMajik »
https://forums.nicoclub.com/blackmajik-u126154.htmlSun Feb 15, 2009 8:28 am
Hey guys and gals does anyone know why my steering wheel doesn't move after I remove the key from the ignition, I've tried setting the location with the cancel button in and out can anyone help me with this problem....
Postby
goody90q45 »
https://forums.nicoclub.com/goody90q45-u31761.htmlWed Feb 18, 2009 5:19 am
You've done the easy stuff now you're going to have to remove the steering column shroud and possibly the trim under it to find the 2 slide potentiometers, one for tilt, one for telescope, and clean them with compressed air or electrical contact cleaner. I didn't have to go this far in getting mine to work so I can't tell you exactly where they're located.
Postby
fixer »
https://forums.nicoclub.com/fixer-u98517.htmlThu Feb 19, 2009 7:29 am
there is a cancel button for auto drive pos. the button is located next to the tilt sw, be sure the adp is not cancelled, also there is a tsb for adp not working. if the seat memory buttons are flashing, replace bcm.
Postby
maxnix »
https://forums.nicoclub.com/maxnix-u127.htmlThu Feb 19, 2009 7:29 pm
BlackMajik wrote:This is for a 94 Q45 and the steering wheel and the seat doesn't retract after key is removed or does it set to position when key is inserted
Please be sure to add this information to your profile so we don't ever have to ask again.
