Steering Wheel Audio Controls
Turtal
I've recently bought an '07 Versa S (was hoping to find a SL, but I got my S for 11,700 so I'm not complaining ), and I know the SL has steering wheel audio controls and the S does not. I've been doing a little searching and can't find the mod to add the controls to the S. Is there even such a thing? Is the wiring there, or am I going to have to run the wire myself, and will my stock headunit even work with it? Am very much in the dark about this and would appreciate any help.
Great White Versa
Car: 2007 Nissan Versa S HB 6sp
I don't know anything about the wiring, but would imagine that it is not in the S.
The head units are different, so if you do find a way to wire the controls, you will need to also buy a new head unit.
Onyxblue
Car: 1990 300zx n/a, 08 Versa SL, 07 Pathfinder SE, 08 Sentra
Is SL head unit pre-wired for audio controls?
equlizer
Car: Nissan Versa SL with SVT transmission
the back of the deck has 3 different plugs (dozzen or more wires in each set) so im guessing the deck is the same and "ready" for steering wheel controls and sub control/power. I wonder if its wired up for it? My local stereo stop took a multimeter to the plugs and most of them came back with nothing. The only thing to do would be to take apart that part of the steering wheel and find out if the wires are there (same for the sub)
ZuZ
Car: Nissan Tiida S 1.6 2008
dude thats awesome..let us know when u check
Onyxblue
My idea is to get a steering wheel with audio control (as my SL doesn't have audio control and bluetooth) and connect the head unit to those audio control.I can try to ask the dealer, but I doubt they will know the answer
kcourtad
Car: 2007 Nissan Versa SL Sedan
sub control from your wheel ??? how do you do that ???
acastrolee
Car: Nissan Tiida 1.8 Special Edition
at least in my tiida 1.8 made in japan there is a steering wheel audio control conector. I order the audio contros from courtesy nissan.but you need to wire the controls to the radio, bypassing the bluetooth control device.theres a lot of info in the service manual.Also I put in my brother car( tiida 1.6) the steering audio controls the same wayyou need to find the conector neer the airbag conector, I think is the m30 and m31 conectors, by the way also works with the base audio system (versa S) the only think that didn´t work was (obviosly) the bluetooth control
any info you can contact me
sorry for my englishI´m From Costa Rica
ZuZ
hey man... can u link me to the service manual plz!i might try installing those
acastrolee
I use the Versa Service manual.search over the forum, you will find ityou need to route the wires from the steering spiral cable to the radioI think are 3 wires for the remote.you will find that the diagram route the cables to the bluetooth module. but you need to install those cables directly to the radioGood Luck.
Onyxblue
acastrolee wrote:at least in my tiida 1.8 made in japan there is a steering wheel audio control conector. I order the audio contros from courtesy nissan.but you need to wire the controls to the radio, bypassing the bluetooth control device.theres a lot of info in the service manual.Also I put in my brother car( tiida 1.6) the steering audio controls the same wayyou need to find the conector neer the airbag conector, I think is the m30 and m31 conectors, by the way also works with the base audio system (versa S) the only think that didn´t work was (obviosly) the bluetooth control
What are the audio controls you ordered from courtesy nissan? Are the ones you install it on the left hand side of the steering wheel?
acastrolee
yeah. those one came even with the cruise control controlsI think the price was like $40good luck
Xradeon
Car: Nissan Tiida 2012 (Versa C11)
Hola acastrolee!! Quiero instalar los controles de audio al volante a mi Tiida mexicano 2012.. He entrado a courtessyparts.com pero solo encuentro el no de parte 25550M el cual lo marca como control al volante del control crucero.. Auque lo indique asi entonces viene con los controles de audio?? Saludos!!
