RP, if you really have a problem with the rack, taking away power (removing best) will not help your "lock-up" problem at all...
If the problem is just that you really don't have any power-assist at those times, and you are calling that a lock-up, you won't be making it any less stiff, but since it won't be a sudden change from assisted to no assist, should feel much better.
I've gone without PS on my 92 vert for a while now, and after getting used to it for a while, doesn't bother me except when parking. My PS pump was screaming so I just cut its belt... Easy "fix".
RagingPanda wrote: Whenever i counter steer quickly my wheel locks up or gets so stiff that it seems lock.
