webbmxer »
https://forums.nicoclub.com/webbmxer-u57415.html
Fri Mar 28, 2008 1:28 pm
hi, i had a problem with my steering so i replaced my powersteering rack, balljoints, bushings, control arms, inner and outer tie rods. had it realigned 3 times. after i replace all parts with new i still had the same problem. when i take a turn either side, while im turning it will jerk harder toward the way im turning which can be dangerous cause it launches me into the other lane at times. also i noticed when i turn the steering wheel all the way the outer tie rods will hit the control arm. i replaced strut assemblies twice with used junk yard ones, so idk they could prolly still be n not the best of shape. when i go to brake, the steering will jerk to one side as well as it does taking turns.
anybody have an idea what may be causing this problem i have?
