steering stops
somedude
the plastic caps on my hardbody have broken off and now when you turn it to the stop it will make the poppin noise. does antone know of a good fix? i was thinking of putting a dab of grease on them but i thought that the bolts would push through the grease and continue making the noise
Big-Bird
Car: 2000 Xterra on 'Roids & 2004 Quest SL
Yes you can grease the steering stops, but this part is not that expensive to replace. You might even be able to locate a used set from the wrecking yard D21/Hardbody casualty.
somedude
i didnt think i would be able to find new ones. i probably could get a set from the dealer but the closest one is an hour away. and if grease works thats good enough for me. thanks
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
grease will help.
