Is it always sluggish or just during autocross?skydragoness wrote:
So is it my steering rack that's bad? Or the p/s pump? My previous S13 never had this issue. So I'm at a loss for what signs to look for when a p/s system goes 'bad.'
At drift events my P/S gets very very hot and stops operating well.
No, I haven't. But it has happened in both of my cars. Our courses are often very technical and require a ton of quick steering inputs. Heats it up quick.Kenrik wrote:Hmm never had that happen did you switch out your p/s fluid?
P/S is very importaint when drifting though, I know a few times where if I did not have it I would have smacked a wall at a very high rate of speed.
skydragoness wrote:Its sluggish all the time now. The steering is pretty stiff, its not awful and its not dangerous, but it's definitely not nimble or as responsive as it used to be.
Rack is probably going out, or the pump is having issues.
Can't remember. He ended up with a pretty solid setup though. He used a cooler as well to keep temps down, and keep it working well.skydragoness wrote:Naed: Did your friend go with a Nissan OEM rack or an aftermarket, and if he went w/ the latter what brand did he get? I've seen some complete racks (w/ gear linkage and 7yr warranties) go for $250 w/ a $50 core charge.
Sounds good. It would be nice if someone made an electric p/s system for the 240 probably would be an arm and a leg though.naed240sx wrote:Can't remember. He ended up with a pretty solid setup though. He used a cooler as well to keep temps down, and keep it working well.
I belive from reading and doing some homework, if you have aftermarket tension rods then you need to get it align to atleast oem spec (6-7) or have it set at 8. Not more. If your having the problem with stock tension rods then your rod busings are probably squirting white sperms, causting your stock tension to play while cornering and bracking. Hope this helps.win2456 wrote:Were you able to figure out the problem? I'm having the same issue on my '95 240sx.
I don't race on track, drift or autocross... I've just run into this problem driving on the streets after getting new tie rods.
It would be really helpful to know if a solution was found... thank you!
