Q451990 »
https://forums.nicoclub.com/q451990-u142.html
Sat Jul 19, 2003 7:46 am
I've finally gotten Q2's renovations underway. My goal is to replace as much suspension rubber at one time so I don't have to mess with it for a while. That means new:
*rear shocks (blues), all new shock bushings and boots*sway bar bushings, end links, and end link bushings*outer tie rod ends and rack boots*rack bushings*tension rods*upper links
Surprisingly, most of what I've removed (including the OEM rear shocks) seem to be in pretty good shape. I think with plenty of treatment, the other rubber bushings should be fine for a long time... Just need to remember to buy some Wurth from T3 while I'm down there.
I'm also replacing the master cylinder, rotors, flex lines (to SS Technafit), installing a transmission cooler, new hoses and T-Stat, etc. Busy week or so ahead.
Anyway, enough background-here's my real question. While replacing the rack bushings yesterday, I removed the u-joint that connects the steering wheel shaft to the rack so I could push the rack up enough to get the left bushing off. While I had it off, I noticed that one joint moves really easily, while the other doesn't. The stiff one isn't super-stiff, or even notchy, but I'm wondering, has anyone ever replaced one of these joints before? It's easy enough to get to without removing stuff, and the steering feels fine, so I'm inclined to not mess with it for now. The car only has 47K and as far as I know Q1's is fine with 196K, so I'm not sure if I want to drop $60 into this part right now - but I thought I'd get some feedback.
Heath
