steering shaft clearence turbo upgrade
95rb25detivoli
Car: 1995 rb 25det forged rods pistons 11 psi
got a rb25 in a s14 im looking to upgrade my turbo and i was wondering if theres any down pipe that avoids the driveshaft as of right now mine hits when i turn hard 3 point turns and what not. just wondering if i need a fabricated one when i get my turbo set up also whats a good turbo upgrade for a top mount on a rb motor rebuilt bottom end forged rods and pistons stock headgasket?
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
if you are going to a top mount turbo you'll need to fab up your own downpipe.
If you notice its your elbow/o2 housing that is fouling against the steering column, so once you move the turbo out of the way you no longer see that problem.
For the turbo to choose what are your power goals and what type of application use are you going for this car? (that'll direct your turbo choice alittle)
BoostFab
Car: S13cp, S13fb, S14z
even the stock manifold and a new turbo, you still need to fab a new turbo-back section
