tetsuo »
https://forums.nicoclub.com/tetsuo-u12026.html
Sun Nov 07, 2004 9:06 am
Thanks alot for the tips. Yes it does adjust toe, and it's was lefty loosey, righty tighty. I know this is a 'way-ghetto-solution' to the problem but I ended up not replacing it (it was slightly bent after a hard bump), but simply re-adjusted the toe manually by looking straight at it from the front of the car and by having the steering wheel in the straight position. I compared how the wheel looks on the other side (which happened to have been aligned not too long ago), made them look identical when standing from the same perspective (just opposite sides). It's hard to explain, but I couldn't believe I was able to do a simple alignment and it goes straight! Now I also know it should be replaced eventually because the structural integrity of this rod is probably gone. But my car is driveable... and sometimes it's a lot.
