Ceptos »
https://forums.nicoclub.com/ceptos-u840.html
Mon Feb 16, 2004 9:24 am
dont take any of this as fact, but from reading through posts and asking questions myself, it could be any number of problems with your front end.
depending on what doesnt feel right, it could be a bushing problem, tension rod bushings could be responsible for vibration at highway speeds or during braking. could also cause odd noises over bumps. (fairly easy to tell, if they appear cracked/dryrotted and/or have rust around them from the liquid leaking out)
your tie rod ends, LCA bushing/ball joint. i dont know exactly what problems they may cause, but they are wearble parts in your front end.
your tie rods themselves do not wear like these other parts and would cause a problem if they are bent, maybe if you hit something. an alignment shop could tell you this. maybe there is a local shop willing to look at your car for no cost.
more specifically, what kind of problems are you experiencing?
