ScottJackson »
https://forums.nicoclub.com/scottjackson-u14976.html
Fri Nov 04, 2005 3:48 pm
read my post about my stiff steering issue. I went thru the whole deal of pulling off the solenoid and even taking apart the solenoid to make sure it was clean after it tested good when hooked to 12V. I then checked the little module for the steering behind the dash between the steering column and radio which supposedly goes out on J30s from time to time. If you have your pump pressure tested at a dealer and the "control valve" in the pump is sticking like mine was due to a little grit, it won't build pressure in the lines and you'll get charged for a new pump, which would fix the problem. but why do that when you could probably fix it yourself for free? The main thing is to be very clean when dealing with the little plunger control valve and the brass sealing washers after you flush the pump out as you don't want to redo the process just because you left a little grime on the brass washer or in the valve.
