DAEDALUS wrote:The shims go between the upper link bracket and the body. A search shows a wealth of info on suspension, alignment and camber adjustment.
http://www.nissaninfiniticlub....44760
Upper link bracket makes a lot more sense than the original reference to the upper links alone.
Thanks.
Q45tech wrote:need 4 - 3/16" shims under the 4 bolts between the upper link mounting bracket and the shock tower metal.......the cheap temp fix.
__________________Brian1995 Q45 & Q45t & 2000 Q45
Discover the power of the button!
