Meantime »
https://forums.nicoclub.com/meantime-u7126.html
Wed Jun 04, 2003 2:02 pm
Okay, here it is straight from the FSM.
To change the steering rack boots, all the mechanic has to do is remove the wheel, take off the outer tie rod nut, remove the boot, clean/grease up the area, slide a new one on and tie it up, then reconnect the outer tie rod nut and put the wheel back on.
It should take a competent (and honest) mechanic no more than an hour to do. Where they got 4 hours from, I have no clue, I would be tempted to actually have the mechanic show you what will require that amount of time. That's pretty ridiculous. Shop around and find someone who will do it for less.
