Richard D »
https://forums.nicoclub.com/richard-d-u133659.html
Wed Jun 02, 2010 8:55 pm
1994 Maxima GXE - I am the second owner.
The steering rack was leaking fluid and I ordered parts to rebuild it.
I ordered the "Seal Kit-Rack" from Nissan, as well as the "Seal Set-Piston" and also the "Seal Kit-Pinion" and shims etc. and new boots so as to follow the instructions in the factory manual to rebuild the steering rack and pinion.
The staked part of the gear housing was already drilled out so I knew the rack was not original on this 150,000 mile car.
However the manual is very clear that after removing the outer and inner tie rods and boots, and then the cover assembly (gigantic nut) I should be able to "draw out the rack assembly". But it won't come out. One of the parts in there won't slide out and stops the rack.
I picked up an A1Cardone rebuilt rack from NAPA and it's clear that the boots are not as heavy duty as the Nissan boots. I imagine that the other parts, seals, etc. are also not quite as good as the OEM parts that I ordered. It seems a shame not to rebuild the rack with a few dollars worth of first class parts, and instead pay a lot of money ($179 plus $100 core) to get second class parts.
Has anyone else tried to rebuild their own steering rack and had this problem? Any solution?
I don't want to trash it to disassemble it and then find that it's worthless as a core exchange.
Thanks for your experience with this procedure.
Richard in South Carolina
