Steering Rack Noise
lovemycarM35
Car: 2014 Lexus GS 350
With F-Sport Package
Nebula Gray
19" wheels
12.3 inch display
Navigation
Ok the dealer installed a new steering rack two weeks ago along with a wheel bearing now I have this rattle when the car hits a pumps its not really loud but it's there something feels loose and when I hit the brakes there's a shuttering like my rotors are warped and they could be cause my sterring wheel has been shaking when I apply the brakes now I'm installing new rotors and pads fromt and rear but that rattle what could this be I'm dropping it back off to trhe dealer on Monday my M wasn't doing that s*** before I dropped it off not really happy with the service
svard75
Car: 06 M35x
You may want to take a breath between sentences hehe
Why did the dealer replace your rack? When they replace the wheel bearing you have to do an alignment. You may actually be experiencing multiple issues.
lovemycarM35
Nebula Gray
19" wheels
12.3 inch display
Navigation
yup they did it under warrenty now I hear this rattle i mean the steering is but fine there is a noise that wasn't there before
lovemycarM35
Nebula Gray
19" wheels
12.3 inch display
Navigation
lovemycarM35 wrote:yup they did it under warrenty now I hear this rattle i mean the steering is fine but there is a noise that wasn't there before
TXT
Car: 2006 M45 Sport
If you didnt have that rattle before they did the work, take it back to the dealer and they will most likely fix that for you.
bryced1
Car: 2007 M35x
I have a similar noise on my m35x.
Kind of a slight rattle when I go over small bumps that seems to be more prevalent on the drivers side (but that could be cause I am always in the driver's seat).
If you find out what it is, please post it up. It has been bothering me!
lovemycarM35
Nebula Gray
19" wheels
12.3 inch display
Navigation
I justt started hearing this after they replaced my steering rack cause that noise wasn't there before and they better fix it I'll post when I get my car back I'm dropping it off today
lovemycarM35
Nebula Gray
19" wheels
12.3 inch display
Navigation
Very good service at Herb Chambers Infiniti of Westborough I dropped my car off and the service adviser wanted the tech to just give it quick look so he had me wait to see if it can be fixed quick. He cam back and siad we found the issue but I'm going to have it keep the car till tomorrow.I then ask him will there be a charge and he siad not one penny I guess my point is the rattle wasn't very loud and my experience with dealers and these issue are not good he didn't tell me what the issues was I'll post when I pick my car up.
OmegaRoach
Car: 06 M35 Tech
lovemycarM35 wrote:Very good service at Herb Chambers Infiniti of Westborough I dropped my car off and the service adviser wanted the tech to just give it quick look so he had me wait to see if it can be fixed quick. He cam back and siad we found the issue but I'm going to have it keep the car till tomorrow.I then ask him will there be a charge and he siad not one penny I guess my point is the rattle wasn't very loud and my experience with dealers and these issue are not good he didn't tell me what the issues was I'll post when I pick my car up.
So what was the problem?
AirDoc
Car: 06 M35X
+1 - I have a similar noise/rattle over bumps - i'm thinking it is either struts/strut mounts being worn out...but i'm new to doing work/maintenance on Infiniti's...so curious to know your outcome - thanks in advance,
s75052
Car: 07 Infiniti m35
16 Infiniti Q70 3.7
Sorry for raising up this old topic again, but just would like to know has anybody known the real root cause as "lovemycarm35" mentioned? Even though written messages to him several times, just no reply. I have replaced my steering rack, stabilizer, wheel bearing, lower control arm, but still exist.
svard75
Car: 06 M35x
This is a good resource on finding the noise. http://www.ericthecarguy.com/faq/diagno ... n-your-car
Hope that helps.
sin1505
Car: 2006 M35x
Did you check the steering fluids? I had this problem and it stopped after I syphon and replace it with ATF
