Steering Rack Leaking (Gear & Linkage)
NYK45
Was told today I have a "steering rack leak" , the part is described as "gear & linkage" runs about $1400 dollars. How big or urgent of an issue is this ?
PapaSmurf2k3
Site Admin
It depends on how big the leak is. It sounds like they want to replace the entire rack for the leak, but if its just a drip every day or 2, I wouldn't worry about it and just keep an eye on your fluid level so you don't lose your power steering. If it gets too low, the wheel will be difficult to turn.
NYK45
I took it to the dealer so most likely that's why they suggested changing the whole thing ; what's the most efficient way to check the leak myself ?
PapaSmurf2k3
Site Admin
What kind of car is it?
You could either jack it up and start the car up, or put it on a lift and monitor the leak while the engine is running (clean the area off, see how quickly the fluid leaks) while turning the wheel side to side.
OR, just keep an eye on your fluid level and monitor how quickly it drops. I always advocate going to a private mechanic shop over a dealer too. They can tell you if its something that can be repaired without swapping the entire rack and pinion.
NYK45
2006 M35
Reason: Moved to correct forum
lovemycarM35
Car: 2014 Lexus GS 350
With F-Sport Package
Nebula Gray
19" wheels
12.3 inch display
Navigation
I got lucky I the dealer replaced the hole rack under warranty a few months ago
