Steering rack leak.
blokespeed
Car: cars
My steering rack leaks PS fluid from the passenger side at the end of the rack.Does anyone know if the seals can be relaced or is it better to swap out for a re-con unit?
180fan
Car: 89 fastback
you can replace the seals. Not too bad to replace either. Pretty cheap but depends if the actual rack has wear on the teeth as well in which case you'd be better off with a new rack.
blokespeed
Car: cars
Does the nissan dealer have seals? or do you know another source?
blokespeed
Car: cars
Ah ha! I found a seal kit at Midway, I'll give it a try thanks for your help.
blokespeed
Car: cars
have you ever changed seals on a rack? , do you have to remove it from the car?
180fan
Car: 89 fastback
you bet i changed seals before. pulling the rack, yes. There's a bushing or was it a seal near the center of the actual metal rack (the part with teeth on it) that requires you pull the rack part out.
blokespeed
Car: cars
I'm struggling to get the lower joint off the pinion shaft, the whole steering column doesn't have to come out does it?
180fan
Car: 89 fastback
yes. think about the pinion and why it'd limit your pulling the rack out.
blokespeed
Car: cars
I got it out! PITA!
180fan
Car: 89 fastback
ha ha ha there are worse things than pulling the rack. seriously.
skylinekin
Car: 1990 Nissan 240SX Hatchback
This goes along with the same topic, I filled my powersteering up with "power steering" fluid but the FSM says to use ATF, will powersteering fluid do and damage? Should I drain the fluid out and put ATF fluid in? Thanks for the help, I just dont want to ruin anything.
navysnail
atf is the best thing to use but i have had PS fluid/ATF for going on 2 1/2 years no problems. i am not saying there won't be any but you should be ok.
skylinekin
ok thanks, now im alittle less worried about it.
blokespeed
Car: cars
180fan wrote:ha ha ha there are worse things than pulling the rack. seriously.
Certainley wasn't fun! I got the actual rack out of the housing today and it has some rub marks and some almost like corrosion marks. So I don't know if new seals will solve my leak problem.
180fan
Car: 89 fastback
yikes. how bad are we talkin?
blokespeed
Car: cars
It's pitted! I think I may have to rig it without the having the power ability and just go mechanical. I just need a way to eliminate the pump but keep the cooling fan driven.
