Steering rack hitting oil pan?
havik420
Car: 91' 240sx RB25
What could be the cause, i could feel it when i turned right... I had the car on a lift prior but didnt notice then..
What could be the cause or how do i fix it
Thanks
Joe
what do you mean when you turned right
your rack doesnt move when you turn the wheel
you need to jack it up, put stands under the lower control arms (so it loads the suspension) and turn the wheel.
havik420
Car: 91' 240sx RB25
Well its resting on the oil pan, and when driving if i turn right it feels like something is snagging, maybe its another issue beside it being on the oil pan...
someone said i need to grind a spot out on the turbo elbow
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
maybe your mount is broken did u take a look at that yet?
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
it's your turbo turbine outlet/elbow. It's hitting your steering column. Since the steering column is a moving part and has a swivle end it's position in regards to the shaft that connects to the rack position varys slightly when rotating. So it's position is not true at all positions of movement. You'll notice an area rubbing away on the cast elbow (if still oem) and a shiny area now on the coloumn.
Solution: modify elbow, or modify mounts, or new elbow that routes around the column.
Hope that helps. It sure sounds like the issue to me. If not, oh well, atleast you checked, :P
Good luck
meet07
Car: 89 180sx rb25det
I agree with coolwhip. The motor is not suppose to move unless your using some soft motor mounts. Me i refuse to use anything factor as far as mounts on such a big engine in a cramp engine bay. Then the check the steering shaft. sounds to me like something is probably loose.
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
*2 for coolwhip!
cory_cnx
Car: 1992 nissan 240sx
x3 for coolwhip!
im having the same freaking problem i tried to moved the mount around .i fixed one time but i went drifting and hit a curve with my exhaust and the motor moved againim using zerolift kitt
