tfvesquire »
https://forums.nicoclub.com/tfvesquire-u83121.html
Thu Sep 04, 2008 4:44 am
If you are simply replacing the boots, then it's even easier than described above. The boot kits I have contain a plastic cone shaped part that goes over the sharp tie-rod stud so you don't have to remove the outer tie rod and mess up your alignment. It looks like a small funnel.
You place the plastic "tool" upsidedown over the stud so the rubber boot doesn't get cut or damaged. Then, apply a small amount of grease to the plastic cone and gently pull the boot onto the outer and inner tie-rods. Then, you can either reuse your existing metal clamps or use the new zip ties from the kit.
One suggestion if you are replacing the outer tie rods: before you remove them, use a bottle of whiteout or other quick drying paint and mark the location of the locking nut. Then, measure the old tie rod(s) with the new tie rod(s) to make sure they are the same length. Then tighten them down to the original location.
Good luck!!
