Steering Rack Boot Replacement
96'er
Car: 1996 Q45
When separating the tie rod to remove the old boot is there enough play in the tie rod to do this with the car on ramps or is it best to raise each side individually so the wheel has some play?
96'er
Car: 1996 Q45
Wheels need to be suspended or can this be done with wheels on a ramp?
Buehler?, Buehler?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
the only way you could do this I think is if you undid both sides at the same time and used the play on the steering rack..
I wouldnt recommend doing that though, i would just lift the wheels off the ground...
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
In any case, no matter how careful you are, things will be seriously out of whack and you will need an alignment.
This is another job where a lift makes access so much easier.
96'er
Car: 1996 Q45
After my post I figured out that it wasn't going to work on the ramps so I am doing each wheel individually.
Maxnix you are correct an alignment will be in order.
What type of grease is used to lube the steering rack? The lube is red in color.
Denver90Q
Car: 1990 Q45 145K miles beige, 1995 Q45t green 80K miles , 1998 Frontier 140K miles black
I think some have been able to do this without realigning by counting the number of threads turned out on the rod? Might want to replace bushings at the same time if you have never done them?
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Denver90Q wrote:I think some have been able to do this without realigning by counting the number of threads turned out on the rod?
That will get you close, but no cigar.
96'er
Car: 1996 Q45
I thought the same until I took it in to get it aligned and was told I wasn't even close.
Haitian_King
Car: 1992 Black Infiniti Q45 /w TCS
1995 Black Infiniti Q45
96’er wrote:Wheels need to be suspended or can this be done with wheels on a ramp?
Buehler?, Buehler?
I totally heard Ben Stein's voice!
Which bushings are you replacing? The guy at the shop told me to remind him to straighten out the steering wheel next time I come in. The wheel will sometimes be turned slightly left even though the tires are straight. I can't remember what thread I saw it in, but I saw a picture of the bushing that's supposed to fix that. Is that the one you're talking about?
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Is this what he is talking about:
96'er
Car: 1996 Q45
No I was replacing the rubber boots that protect the steering rack.
unknown007
Car: White 1993 Q45 (G50)
I'll be doing the replacement soon too.I'm gonna lift the car in the air makes it much easier. Good luck to me and you.
goody90q45
Car: 1992 Infiniti Q45 (sold)
This thread may help to answer some of the questions.
zerothread?id=291740
Q451990
Haitian_King wrote:The wheel will sometimes be turned slightly left even though the tires are straight. I can't remember what thread I saw it in, but I saw a picture of the bushing that's supposed to fix that. Is that the one you're talking about?
Unless the steering wheel is way way way off, that's something that the alignment should fix. As long as you have roughly the same number of turns center to lock each way, it's in the alignment.
Heath
mxr662
Car: 1990 Q45 Desert Sand 81k Sold
I counted the turns on the tie-rod ends and it was very close. As I pried up gently on the steering rack, the rack would move forward, not allowing the new insulator to slip in. I placed a socket between the crossover and rack then pried, the rack moved straight up allowing the insulator to slip around the rack.
If I had it to do over I would have replaced the tie-rod ends also.
Do the rack insulators while your there. It's easy and cheap.
