x2 alignmenttom1012 wrote:My steering will pull to each side. It is worse to the right, but depending what side its already on.. it tends to curve off if i let it. The steering will also wobble and act weird if I drive on snow. Can I have some ideas of might b wrong? Is it a do-it-yourselfer?
plus check the ball joints if their leaking oil... replace them asap!weird240 wrote:before they align it have them check the front end for loose tie rods or ball joints. they have a big effect on the alignment if the r loose.
