Chad91Q45 »
https://forums.nicoclub.com/chad91q45-u18243.html
Mon Jul 26, 2004 6:08 am
Ok, so I drove my Q to work for the first time today and I am having a few steering problems I think.
Last night I apparently parked ****-eyed with one wheel on a 4x6, the other on flat ground (my Aunt whom I am staying with for the summer to work kinda lives in teh ghetto).
So starting it up, no problems, no noises.
Up until 35, no problems at all.
From 35 on, it kinda of shakes like tires are out of alignment.
Once I get on the highway and I am doing 60, there is a high pitched whirring noise and the wheel is ****eyed, too, once again making me think that the tires are out of alignment, but I pull over because of the whirring noice.
Pop hood, nothing unusual. No smells, noise is gone, everything looks peachy. Only have 3 more miles to work, so I let it slide for the time being.
Get off highway, done to city speeds, once again at 35 or 40, the shaking and whirring noise disapear.
Park car at work, notice a little bit of smoke coming out of the engine compartment. My temperature and oil had stayed fine. Pop the hood to try and see where smoke is coming from. Appears to be coming from drivers side, far back in the engine, and kind of deep down, or at least not right on ethe surface.
So any ideas what could be causing this? I am wondering if maybe the whirring noise was the HICAS that it was being activated since I was having to hold the wheel ****eyed to drive straight, possibly from misaligned tires.
What should I do in the meantime? I am going to check powersteering fluid and make sure that is fine. Is there an easy way to disable HICAS and the powersteering?
Please help!
